2nd gear grind
RE: 2nd gear grind
if the shifter has adjustable stops, you might try adjusting those and see if it helps any. This may help, Good Luck. I had to adjust mine a time or two when I put in my B+M Ripper Shifter. Just a suggestion.
RE: 2nd gear grind
ORIGINAL: Dan89lx
agree... i have my b&n ripper shifter stop points basicly not being used... just let it go as far as it can.... but if you have those adjusted, it will not let it engage all the time, i was playin around with mine and figured that out on my own[&:].... but i would bet your synchros are gone, mine does it in 4th gear everytime
RE: 2nd gear grind
ORIGINAL: import slayer
The tranny in my '88 grinds in second gear too but I just double clutch 2nd everytime.
It just comes natural now to double shift.
[sm=dontgetit.gif]
RE: 2nd gear grind
ORIGINAL: bobby
what r some tricks when installing a short throw shiftr? anything u have to watch out for? we want to get one for the 05................................
its easy boby, i would go and get one for that thing, shouldnt take to long to put in.... its pretty straight forword
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
