explorer block...
RE: explorer block...
ORIGINAL: ovalracer98
The explorer motor has different pistons giving it only 9:1 compression with the 58cc chamber GT40P heads. The pistons are also hypertechnic not forged like the 5.0HO pistons.
ORIGINAL: gspfunk
The pistons aren't what changes the compression...the heads have smaller chambers. The pistons are the same hyper pistons used in 93+ stangs.
or is that too difficult?
If the pistons were not different then dont you think that just maybe that the compression would be higher than 8.8:1-9:1 with a 58cc chamber on explorer block?? think about it... If you were to take a 58cc head and put it on 5.0HO block you would have around 9.5:1 ratio. Pistons have to be different
ORIGINAL: AdderMk2
Excuse you??? Did you ever think that maybe the pistons in the exploder motors had a larger dish for better quench??? thus reducing the compression ratio?
ORIGINAL: gspfunk
ovalracer, that's something I hadn't thought about...thanks for the correct (and detailed) explanation.
waid302
09-14-2015 11:19 AM
