header size?.4
header size?.4
hey im looking to get some bbk longtube headers, but im not sure what size i should be looking to get.. do i go with the 1-3/4" or with the 1-5/8"??...they range from 397 for the 1-5/8" to 459 for the 1-3/4", and should i go ceramic coated or chrome?
RE: header size?.4
go with the 1 5/8 the 1 3/4 are too big if your pocket book will allow get the ceramic but the chrome work just as good. i paid like 400 for mine with the matching h pipe from brothers performance(chrome)
RE: header size?.4
yea the chrome headers are like 100 bucks less than the ceramic ones are...my plans are some afr heads, a cam and a kenne bell or a turbo in the near future, so i am trying to build up the base for that..how much better are ceramic than chrome?
RE: header size?.4
Chrome vs. Ceramic coating - Chrome finish is intended to provide protection for the header. The chrome will "burn in" and some discoloration will occur when heat is applied. A chrome finish, when maintained properly will give you many years of service. Ceramic coating is a high luster silver color, and looks like highly polished aluminum. It will not discolor with the introduction of heat and is corrosion and heat resistant to 1000 degrees. At the same time it creates a thermal barrier in turn lowers the under hood temperature and adds life to your header.
RE: header size?.4
I personally would spend the extra money on ceramics. Chrome headers turn rainbow color and eventually can rust if not maintained. Ceramics should look better for longer and also help with heat as stated above.
RE: header size?.4
ORIGINAL: OnyxCobra
Go Ceramic! you will be happier in the long run. i promise
09-10-2015 08:39 PM
Other Professional Racing
09-10-2015 11:41 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
