94 gt 5.0l 5sp. vortech sc. got on it leavin town and a ton of smoke came out of nowere, so i shut it down and saw the dipstick was blown off alittle and oil was coming out of it. no oil or a/f out exhuast, plugs look good, o2s readin good. what would be a cause of this???
Plain and simple, there is only ONE way pressure builds in the crank case... blow-by. Combustion pressure leaks past the rings and pressurizes the crank case. Now, if you say the pcv system is new, then it is either not adequately venting the pressure or you are simply building too much pressure which is caused by bad rings or out of round cylinders. How many miles are on this motor? If it's got alot of miles and you just slapped a blower on it, then you were asking for trouble.
