timing?????
RE: timing?????
Youshould be able to read the numbers by the crank for the timing marks. Usually you will find zero and anything to the right or clockwise will be advanced and to the left or counterclockwise will be retarding the time. Also should say ATDC and BTDC on it to help ya out. I just put white out on whereever you want it to be set at like 10 is stock for example and line it up on your timing mark with a timing light.
RE: timing?????
i have a new balancer on it and it only goes back 10degrees but goes clockwise 40 or more so i should set it at tdc and then retard or advance i am running a 50 shoot of the juice plus i have a supercharger the motor has edelbrock heads new pistons rods stage 2 tf cam 1.6rr edelbrock upper &lower 24lb injectors 70 mm tb 75mm maf so were should i start?
RE: timing?????
even with no nitrous the motor must be tuned. the sc alone requires a dyno tune, the nitrous just makes it that much more important. a 50 shot on a boosted motor will be like a 75-100 shot on a N/A motor
RE: timing?????
If you know the brand balancer if you didnt buy it yourself you can do a quick search and see how it is set up. I do know that clockwise on the crank is advancing it and moving counter is retarding it. I cant ever remember which way to move the distributor unless im actualyl doing it.Start at 0 and go from there.
