frustrated!!
frustrated!!
ok so i tried mocking up my subframes getting ready to weld them up and i lifted the car on the hoist as it says. jacked up the subframe as it said. ( btw these are full length subframes with cross braces and "torque box adapters") and they are really close to lining up but theconnectors still hang a little lower the subframe itself in the rear part of the car. do i have to have these "torque box adapters" welded in first for them to work....i dont see how they go on. they are square and flat, one side flips up at a 90* angle and then on an adjacent side there is a tab that flips up at 90* angle.....any help would be great.
RE: frustrated!!
ORIGINAL: AdderMk2
you shouldnt be lifting the car at all.. It must remain flat, and under its own weight.. meaning all four wheels have to be on the flat level surface
RE: frustrated!!
ORIGINAL: AdderMk2
RE: frustrated!!
i drove it on to a lift and we lowered it on to jacks to level it out on the sub frame exactly how to says on the directions but the connectors dont quite mesh up correctly yet, a little off maybe about....between 1/8 and 1/4 inch would that be tolerable or is that off?. so i was wondering do i have to have those torque box adapters on? that doesnt sounds right but maybe thats what i have to do. i dunno.....
i have never done these before so if this is still wrong just tell me.
RE: frustrated!!
ORIGINAL: FivePointOhh
mmmm....i kind of want to disagree with you. for two reasons. one the instructions say to do it this way. and two why would i want to fortify my body sag? i want to straighten my body out. if you have other suggestion to try and help me get these bad boys on i would appreciate it. btw its about 2 1/2 inches off without jacking up the subframe.
ORIGINAL: AdderMk2
mine were done on a body shop frame machine... so I know my **** is straight
