ok need help
ok need help
my car is really starting to **** me off . yesterday i died on me and i started it back up and was under hood and reved up on it and it like died and started back up and spit gas out of carb . so i thought maybe fuel pump was bad . took it off little bit ago and the shaft is stiff as hell and it is sucking so i dont think its that now . is there a chance my car has electric fuel pump and manual . before when would shut off car sounded like fuel pump was shutting off or something in the back but im so damn confused right now and have no clue where to turn next . like said yesterday when reved up it would like die and be running again . and then got it to start back up and i let it idle for like 5 min and thought was all good and went to take off and nothing and why did it spit gas out of carb ? when it dies it will start back up if let it set for few min but wont run to long . guy need help on this please thanks .
RE: ok need help
well damn not tryin confuse ya lol . jus needing some help cause im lost on it . if wasnt getting gas or anything would that make it backfire like hell . cause it did that yesterday also when it died on me . my dad thinks maybe timing chain is bad or maybe broke the cam but if broke cam would it still start and run for little bit .
RE: ok need help
thats what im bout to go do he told me put a socket on crank and turn it and see if there is some slop in it and maybe take vavle cover off and turn motor over and make sure vavles are working . im thinking bout jus yanking damn motor out i know a guy that has a cobra engine with gt 40 heads on it and bigger cam and he wants to trade me my weld wheels for it dont wanna get rid of wheels but this car is pissing me off bad lol .
RE: ok need help
isnt of getting pissed off and saying screw it, take a breath and take a look at your problem and try to trouble shoot it until you fix your problem. if your gonna get frustrated so easy you dont need a mustang
RE: ok need help
do you have a mechanical pump? if your using a in-tank then you need a regulator for about 5-6 psi....another thing timing will may it spit up thur the carb.....I believe what is happening is you have too much pressure and it flooding the engine becuase the needle and seat don't have enough tension to close when the float is up
RE: ok need help
it always ran fine before and min ago turned crank pulley and it dont have any slock at all in it and turned motor over to check vavles and all those are working like should . im jus lost checked bout everything dont know what else could it be
