Fog lamp problem
Fog lamp problem
i have a 1991 mustang gt i just put new fog lamps in and they wont work i hit the switch and no lights. any one have any ideas? i looked at the plug and its connected and the wires look fine. any ideas would be helpfull.
RE: Fog lamp problem
There is a seperate fuse in the panel for the fogs. Try that, if no then I'll listen to other replys cause mine don't work either and my fuse is good. I took mine out temp like so I can pass inspection!
Perhaps a stupid question, but did you turn your headlights on with the fogs? If you have a multimeter, check to see if you have a good ground and that you are getting power to the sockets. If you have no power, check your fuses, and check to see that you are getting power to the switch. If you are getting power to the switch, and your fuses are good, you probably got bad bulbs. BTW, my bad on my stupid *** post up there... didn't notice the GT.
Vic
Vic
stangin1996gt
09-21-2015 11:01 AM
