installing new cam HELP
Im buying a new trick flow stage 1 cam for my 94 gt. My question is do i need to replace anything else with the new cam? What exactly needs to be done do i have to take apart the whole topend of my motor or just the front?
RE: installing new cam HELP
ORIGINAL: rcdblink716
I'm pretty sure u can use the stage 1 on a stock bottom end, but I don't think stock heads will take that much lift.
not to mention its not gonna make any more power anyway
i read somewhere that the stock springs are only good up to .500 lift. I believe that the TFS1 is .498/.512. When i did my hci with the TFS1 cam and GT40P heads/intake,i bought a kit valve spring kit (springs,retainers,locks)from crane cams with springs good up to .565 for around $120 or so. Definately get springs that are made to handle more lift......
You will also need a new timing chain, necessary gaskets,also wouldnt be a bad idea to getnew lifters
Luke9222
10-22-2015 11:55 PM
