Finished Project 65
Finished Project 65
I hope ya'll don't think this is in the wrong location, just wanted to put it here since ya'll have helped a lot. I justgot the project on my 65 gton the road a couple of weeks ago. It's not complete yet but I'm gettin there. Hadn't shared n e pics so I figured I'd post some. Most of the mods are in my sig but I'll repost.
*Ford Sportsman Block
*Eagle Race Prepped Crank
*Forged Eagle I beams
*Probe SRS Forged Aluminum Flat Tops(Full Floating)
*Trick Flow Stage 2 Cam Retarded 2 Degrees (Soon to be custom grind)
*New Ford Racing Hydraulic Rollers
*Hardened Trickflow 5/16 Pushrods
*Trick Flow Track Heat Heads
*Crane Gold Race Roller Rockers
*Trickflow Billett Adjustable Double Roller timing Set
*Parker Funnelweb High Rise
*Mighty Demon 650 Mechanical Secondary
*Dynomax Ceramic Coated Headers
*Fidanza Aluminum Flywheel
*Msd Pro Billett Dist.
*MSD Digital 6 Box
*Blaster 2 Coil
*Stage 4 Zoom Clutch
*Cage
*Subframes
*Thru-Bolt Polyurethane Mounts
*Hurst Short Throw Shifter
*Fully Blueprinted, by me
*Internally Balanced
*I'm Sure There Is More
*MSD Digital 6 Box
*Blaster 2 Coil
*Cage
*Subframes
