nitrous purge questions
ok well it looks like(crossing fingers) im going to be buying a nitrous kit this weekend, depending on my paycheck. i no how im going to hook it up and wire it and all. now the questions
i have a spare nitrous silonoid, can i use that to purge?
where do i put it in line, i assume right before the nitrous silonoid. but how does it get spliced in?
do i get a Y fitting, and have one go to the nitrous, and the other purge? or what exactly?
RE: nitrous purge questions
a regular nitrous solenoid is a bit big to be used as a purge... it will create an unwanted drop in your tank pressure, and cost you more money than it should, every time you purge
The nitrous solenoid will work for the purge.Depending on what kit you buy ,some nitrous and purge solenoids are the same size.Im pretty sure that zex uses the big solenoid for their purge kits.
[IMG]local://upfiles/29615/5BFE599422BB434B878B4E73EF052925.jpg[/IMG]
good ****, that pic helped alot..
also the wiring... i think i have it good, but u guys, w. nitrous, tell me...
power---on/off---window switch---WOT switch=====both silonoids====ground
-- is one wire
== is two wires
also what size wiring should i get?
-- is one wire
== is two wires
i just got my nitrous kit from the UPS guy.... i got the basic EFI NX kit.... bought it used form a guy on there... i can help much cuz im sure ull have yours on b4 i have mine on... i need to get my car tuned first.... i was wondering if i could hook everything up tho??? i dont have the tank filled... also can u take pics for me if u install yours b4 i install mine??? it would help me a lot
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
