HEADS
Old 01-09-2005, 07:13 PM
  #101
Quik
Quik's Avatar
Default RE: HEADS
1.72 and 1.73 cant make that much of a difference... its a freaking thousand so youll go from .444 to .477 to .480...that little you wont see
Quik is offline
Old 01-10-2005, 03:48 PM
  #102
roundman
roundman's Avatar
Default RE: HEADS
ORIGINAL: 91hatchgt
Roundman, thank you for your reply, YEah I was wondering.. Well I guess I will have to go with the AFR's DARN!! lol.. Yeah the E-303 is the legal cam, but I hear if you put on 1.73's you can almost match the performance of the E-303 with the stock cam. I was thinking about the AFR 165's and that new BBK upper/lower... Heard anything about this combo Roundy? Anyone?
there are other street legal heads out there other than the AFR's but they wont' make quite the power of the AFR's according to the test results I've seen. I'm sure the BBK intake would work well with the AFR heads, but you are still being held back by the cam which has to keep you emissions legal, so I don't know if I would spend big bucks on another intake right now. why not try just the cam and heads and see how this works for you and the emissions testing before you go any farther with the mods? this might save you some bucks in the long term too.
roundman is offline
Old 09-12-2006, 07:50 PM
  #103
only90s
only90s's Avatar
Default RE: HEADS
Ford Racing claims 345 horse out of their 302 Crate Motor with the GT-40X heads.. So either they are lying or those heads are pretty good.
only90s is offline
Old 09-12-2006, 08:40 PM
  #104
Dath
Dath's Avatar
Default RE: HEADS
They are a good head.
Fun Fact: This thread is almost 2 years old.
Dath is offline
Old 09-12-2006, 11:34 PM
  #105
bouchermb
bouchermb's Avatar
Default RE: HEADS
What brand/model heads would you go with if you had my mods? I've been hearing arguments for bopth 165 and 185's and regardless since I have an 86, I'll need to get the pistons notched anyway.
Vortech 5 psi SC, 70 MM TB, 73 MM MAF, 30 lb. inj., 190 lph FP, pulleys, Mass Air Conversion, aluminum rad, electric fan, TF Street intake, equal lengths, 3"mandrel bent x-pipe, MSD 6AL box, blah, blah, blah.
bouchermb is offline
Old 09-13-2006, 01:56 AM
  #106
mrbigshot
mrbigshot's Avatar
Default RE: HEADS
http://airflowresearch.com/articles/article087/A-P1.htm
bone stock 5.0 shortblock, stock ho cam, afr 165's, small carb, 1.7 rockers, street intake = 400 hp
mrbigshot is offline
Old 09-13-2006, 02:00 AM
  #107
dimebag
dimebag's Avatar
Default RE: HEADS
wow...this shyts OLD.... why has this been happenin alot recently?
dimebag is offline
Old 09-13-2006, 02:13 AM
  #108
Dath
Dath's Avatar
Default RE: HEADS
It's all in what you want and how you drive. I drive it hard . So I went with a lower compression set that will allow me to add 8-9lbs and hopefully not kill it as fast.
Dath is offline
Old 09-13-2006, 07:03 AM
  #109
89GTRed
89GTRed's Avatar
Default RE: HEADS
wow how the hell did this post even get dragged out of the closet? Good inforative thread but geez....
89GTRed is offline
Old 09-13-2006, 10:53 AM
  #110
bouchermb
bouchermb's Avatar
Default RE: HEADS
Appreciate the input and I'll cehck out that link now.
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: HEADS
