trick flow intake???
i am looking to buy an intake and i am looking at the trick flow street and the trick flow track heat but i amd building a 331/347 stroker and puting on twisted wedge heads i see the test for there kits and the street makes 20 ft lbs of tq and 10 less hp that the track heat would the track heat out perform it on the bigger motor or would the street still have a decent tq advantage. i am using a 1' spacer with either intake. or if there is a better intake i am open to suggestions.
RE: trick flow intake???
Neither of those tests were done on strokers. If you must limit yourself to those two choices, go with the Track Heat. Otherwise, I'd go with a Holley or Performer RPM 2 intake over the Track Heat.
i knew the holly out performed them both but will the ports match up good with twisted wedge heads and prob a trick flow stage 2 cam(wanted it to match thats kinda why i was looking at track & street)
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
