My guesstimation on power turn.
Old 06-08-2007, 10:42 PM
mcfomco
mcfomco's Avatar
Default My guesstimation on power turn.
I have 2 different setup options.
#1 Will be stock short block freshened with new bearings and ring. (this short block will be used on both)
F-cam
gt-40 heads with 1.940 int and 1.600 extmild to heavy port work not cnc.
(To give an idea these heads have been port matched to the 1250 fel-pro gaskets intake the exhaust matched to 1415)
1.6 roller rockers
PP Typhoon intake (same as Edlebrock RPM)
24lb injectors
73mm c&l meter
65mm t/b
150 shot of silly gas
#2 Will be same block as above
TFS stage 2 cam
TFS TW heads same amount of port work 2.020 int and 1.600 ext
(To give an idea on these heads. They have been port matched to the 1262 fel pro gaskets intake and the exhaust 1415)
1.6 roller rockers
PP Typhoon intake ( same as Edlebrock RPM)
24lb injectors
73mm c&l meter
65mm t/b
I know this gets asked alot on here and you hate seeing it. Sorry for the same ole question but I just wonder what it might actually put out. I have some idea's just wanna see how close I am.
Thanks Alot for those of you that reply in advance.
mcfomco is offline
Old 06-08-2007, 11:50 PM
mcfomco
mcfomco's Avatar
Default RE: My guesstimation on power turn.
Come on someone take a stab at it.
mcfomco is offline
Old 06-08-2007, 11:59 PM
MustangMadness7
MustangMadness7's Avatar
Since i feel bad that no one else is guessing ill throw in my 2 cents. First setup ill say 287rwhp off the gas, and 442rwhp with the shot. Second ill say 302rwhp off the gas, and 451rwhp with the shot. Im not a fan of letter cams, so i said the TFS will do a little better, but really they oughtta be very close if the GT-40's are ported that well.
MustangMadness7 is offline
Old 06-09-2007, 01:22 AM
mcfomco
mcfomco's Avatar
I am not a big fan of the letter cams either but its installed in the short block already. Anyone else care to guess.
mcfomco is offline
Old 06-09-2007, 02:21 AM
mcfomco
mcfomco's Avatar
Come on now I am not a newbie here. I know more than one person has some sort of idea what it should make.
mcfomco is offline
Old 06-09-2007, 02:31 AM
dimebag
dimebag's Avatar
dunno wut it would make man... but if i had to put money on one of the two... it would be set up number two
dimebag is offline
Old 06-09-2007, 02:56 AM
mcfomco
mcfomco's Avatar
I have the stuff to do the #2 setup just setting here. I have a local here though that needs a good *** bustin motor to motor. So I need it to appear stock headed for atleast a few days. I am getting the short block for sure just trying to decidehow long I wanna leave the gt40's on after I tend to some *** bustin. Some people will never learn. You dont run your mouth when you know the other person has stuff laying around.
ORIGINAL: dimebag
mcfomco is offline
Old 06-09-2007, 10:26 AM
mcfomco
mcfomco's Avatar
ttt
mcfomco is offline
Old 06-10-2007, 04:49 AM
mcfomco
mcfomco's Avatar
ttt
mcfomco is offline
jrrhd73must
10-02-2015 09:17 PM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
Quick Reply: My guesstimation on power turn.
