motor mounts
Old 06-09-2007, 06:35 PM
GaryBisiniere
GaryBisiniere's Avatar
Default motor mounts
so i have stock motor mounts in my 89 notch and its a built motor with a big cam. every couple of weeks i notice the motor leans to the right. should i look into new motor mounts?
GaryBisiniere is offline
Old 06-09-2007, 06:39 PM
w8less
w8less's Avatar
Default RE: motor mounts
i would seriously consider it.
i had the energy suspension ones on mine
w8less is offline
Old 06-09-2007, 06:43 PM
GaryBisiniere
does your motor stay aligned? how is it at an idle does it move at all?
Old 06-09-2007, 09:49 PM
ovalracer98
ovalracer98's Avatar
I would get new ones, mine were totally torn in half when i repalced mine with ES poly mounts
ovalracer98 is offline
Old 06-09-2007, 09:55 PM
Quik
Quik's Avatar
anytime you got built motor or etc. urthene mounts are atleast recomended. some even consider solids. i run solids on my truck and i have urthene on hte notch
Quik is offline
Old 06-09-2007, 11:44 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
never solid for a street car that;s just silly.......I use a small cable to one head and to my frame... I know 1968 chev impalas came from the factory with this cable
2 kwik is offline
Old 06-10-2007, 12:33 AM
dimebag
dimebag's Avatar
the cable idea is a good idea... they actually sell **** like that... but just go w. the cable idea.
dimebag is offline
Old 06-10-2007, 12:56 AM
ovalracer98
I personally would shy away from soild mounts in a street car, the vibrations are terrible. Even with poly mountsthere is a little vibration but is not that bad. IMO solid mounts should be for a race car unless you can bear with the vibrations on the street.
Old 06-10-2007, 05:04 AM
Quik
Quik's Avatar
actually in some cases the solids dont vibrate at all compared to stock. with my old truck setup the old tamer motor rocked the truck. nowwith the new 408 the truck doesnt shake or vibrate. truck is also a full frame vehicle.
Quik is offline
Old 06-10-2007, 10:25 AM
87ttopGT420
87ttopGT420's Avatar
PROTHANE MOUNTS WOOOOOOOOOOOOOOOOOO couldnt ask for any better of motor mounts and tranny mounts
87ttopGT420 is offline
Quick Reply: motor mounts
