charging issues
06-09-2007, 07:03 PM
charging issues
i can't figure it out.
ok brand new battery new terminal ends and the alt tested fine. why does the battery light keep coming on?
when i am driving it comes on but when i am idling it shuts off
06-09-2007, 08:48 PM
RE: charging issues
are you actually losing power or does the warninglight just come on?
06-09-2007, 10:06 PM
RE: charging issues
light just comes on i can't figure it out for nothing any ideas?
06-09-2007, 10:52 PM
RE: charging issues
does it come on when you rev the engine
06-09-2007, 10:56 PM
RE: charging issues
maybe the voltage regulator is overcharging, making the light come on when you rev the engine up. Check that, it is a free item to try.
06-10-2007, 12:07 AM
The Rogue Mod
RE: charging issues
It's internal in the alt. I had the same issue, sent it back to PA Performance,(warranty) they rebuilt it, problem solved.
06-10-2007, 12:29 AM
RE: charging issues
Quote:
ORIGINAL: PRO50SC
so it is not the regulator, sorry for the bad info.
06-10-2007, 02:21 AM
RE: charging issues
its on my moms van just trying to get some info
06-10-2007, 06:58 AM
RE: charging issues
Did it do this with the old battery and terminals? Doublecheck your connections and make sure theyre all tight.
cr620
10-03-2022 10:18 PM
CS2007
06-25-2019 09:45 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
UrS4
09-30-2015 10:13 AM
