saving up for novi 1000
#22
RE: saving up for novi 1000
hoping for 450 on the dyno. Havent been to the dyno yet.
i would look on ebay. Heres a link, if your guna go to 10psi i would take the free fuel pump
http://cgi.ebay.com/ebaymotors/PAXTO...spagenameZWD1V
#23
#25
Best thing to do is go to like superchargers.com or something like that... They will sell a kit, some places you get the charger, injectors, pump, mass air, and all the components needed to run a safe system... Some also provide a tune that come with them... It isn't always gonna make the most power, but it will keep it safe... Thats the route i'd go if you aren't planning on dyno tuning...
Otherwise, i'd buy 42lb injectors, though 30's will work... But if you use the 30's, you might wanna get an adjustable fuel pressure regulator for some security... Get a quality blow thru mass air meter calibrated for your injectors... Purchase you a 255lph pump for the tank... Also, if its in the budget, go with an intercooled setup so that you can run more boost and make more power safely... You'll be glad you did... Good luck
#26
ORIGINAL: BackInBlack90LX
will my stocks intakes be able to handle a s/c
Also, i've heard not to use underdrives with chargers...
#28
Novi 2000 moves more air than the 1000 and is capable of more boost. Novi 1000 is an awesome entry level S/C. It can produce up to 15 psi which is more than enough for me. Here's the kit that I just bought for $820. Way better than a set of aluminum heads IMO! Mine came with 3 different boost pullies and an AFM power pipe. I ended up purchasing an FMU (until I canafford injectors and anotherMAF)and the TAP and Punch for the oil pan. I also found a brand new Walbro 255lph fuel pump for $87 (bought that last week). Now all that I need is the fitting for the oil pan and the attaching hardware for the oil lines and mine is ready to go in.
