1.7 roller rockers on E7s ?
would I have anyclearance problems or need different pushrods.
Im running the E cam and ported heads w/ 3angle v/j, non emission.
and if I can putem onn about how much would I gain? would it be worth it?
RE: 1.7 roller rockers on E7s ?
You might see a gain, depends on how much those heads are ported. If they are ported enough you may see a 10-15hp increase.Only way to know if theres going to be a piston to valve clearance problem is to check the piston to valve clearance.
69MustangCoupe393cid
10-03-2015 10:33 AM
