remand tranny
RE: remand tranny
ORIGINAL: dimebag
um sure...
here man...
drop the mid pipe
drain the trans...
remove the d shaft
put a jack under the engine, one undr the trans
unbolt the crossmember, and trans from bell housing
back the trans up
drop it
reverse this all
i dotn care how ur clutch is... unless you just put it in 2 months ago... replace it and the t/o bearing.
um sure...
here man...
drop the mid pipe
drain the trans...
remove the d shaft
back the trans up
drop it
reverse this all
RE: remand tranny
did i not say... unless its new... uh... 600 miles is JUST broken it... it would be stupid to replace it.
and do the t/o bearing, its just piece of mind, tho its prob. fine too, because i assume u did it w. the clutch.
and no i wasnt being technical, i can if ud like tho... however to ans. ur other questin, no no calibration, just set it in and fill it up and call it good
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
