problem... im at a loss...
ok this didnt start happening untill last night.
whenever i turn left, i get a bad sound... it almost sounds like the right tire is rubbing on one of those inner fender flaps, which is originally what i thought it was when driving... BUT... i got in the driveway, and turned it left, and it made the noise... so i stoped the car(still running), and expected it to go away, but no dice... w. the car out of gear, and wheel turned left, i get that sound again, it sounds like its comming from the bell housing or motor[:@][:@][:@]. but i haven o idea what in there would make noise only when the wheel is turned left...
RE: problem... im at a loss...
yea mattdel, thats what im sayin...
and yea i just got home from work, im gonna go out and wash it, mount the nitrous shyt, take off the DRs and do a full shake down on the steering/suspension. got alota **** i need to do out there... this is just one more thing to add to the list i guess
ORIGINAL: 945LSTANG
that happened to me when i had a bent tie rod end. check urs out just in case its the same thing.
well, dimebag, i'm at a loss here too, without being there to hear location and type of noise...
i noticed you mentioned something about an astro tranny, how recent was this? what are the chances that the bellhousing-to-block bolts have come loose?
maybe a bad tranny mount?
you got me baffled, man.
yea i havent hit n e thing or n e thing like that at all... its all been normal drivin, nothin crazy... well sept the track often, but no hard pot holes or n e thing....
**** i hope its somethin simple
ORIGINAL: mattdel
how the hell do you bend a tie rod end? jesus christ, learn how to drive
ORIGINAL: 945LSTANG
+1, on checking the bellhousing bolts and the trans to bellhousing bolts. I forgot to loctite the trans to bellhousing bolts once and 2 of em backed out completely and the other 2 were finger tight[].
-P.
-P.
the bellhousing to block bolts are good, i just did a clutch 2 weeks ago or so... there tight, im sure... the trans is from back in jan...
i would think it were these... IF... it didnt start happening untill last night...
