yes you can but you will have to do somehtign with your egr ****. also with out the plate you will need a mounting bracket for your linkages. also you will now be shorter with your air tubing. im thinking of this with my set up
why not just remove the EGR valve from the spacer plate and plug up the passageways in the plate with some marine epoxy so it can't leak in any air and just cut a metal plate to fit over the studs where the valve installs and seal the bottom side of it with some RTV and put the plate on in place of the EGR valve, then you can remove the cooling hoses from the plate too and leave everything in place where it already is.
