Electrical Problem
Electrical Problem
I have a 95 GT and I was doing some shade tree work and arced something. My turn signal lights come on but don't blink. My hazards won't even come on at all and I have checked all fuse both under the hood and under the steering wheel. Is there a multi-flash relay I don't know about, and where might it be?? By the way, I know I should've unhooked the negative cable, so please be gentle with the jokes...
Thanks,
Tom
Thanks,
Tom
RE: Electrical Problem
yeah it's called a "flasher" look under your dash, passenger side
http://autozone.com/addVehicleId,177...leSelected.htm
ORIGINAL: Hawk
Just throwing it out there, but you did make sure you didn't have a burnt out bulb correct? I know that if one bulb dies it can actually make the rest of your lights/signals/etc not work.
Can anyone email me as to where this flasher is?? I have looked under the driver side and passenger side dash, took off the cowling and mini firewall under the steering wheel. I have taken off the Kick panels on both sides and now I am wondering if I should take out the mount for the fuse box on the drivers side if it is p;ossibly connected there. I am also wondering if maybe it is in the center console. If anyone knows and can send me a pic, I would appreciate it. tsnyder928@yahoo.com.
Thanks
Thanks
i had a problem with my signal lights after hitting a deer. the lights would all come on but would not blink. i ended up replacing that bulb and everything worked fine after that. those bulbs have dual filiments for marker lights and signals so its possible the signal side is burned out and not letting and of the bulbs blink.
The lights themselves are fine, as well as the fuses. The question I have is, is the Flasher relay located on the flip side of the fuse junction? On other cars I have worked on it is like this beacon staring at you in the face when you go to replace it. I have looked under both kick panels and I have started to take out the pieces of the dashboard under the steering wheel looking for this damn thing. According to the manual I have it is jutting out from the fuse panel, but damned if I can find it. Thanks in advance for all the suggestions in regards to other alternatives, but I know this to be the problem. I just can't find the thing!!!
uberstang1
09-20-2015 06:42 PM
ccdguy
09-19-2015 05:20 PM
TfcCDR
09-14-2015 12:08 PM
