Car breaking up around 4,000+ rpm
Today when i went WOT to about 100mph, the car was kinda breaking up around 4,000-5,200rpm.. what could cause this? i was thinking another vacuum leak..?
RE: Car breaking up around 4,000+ rpm
the same thing is happening to my car, but im not doing 100+ mph, mine sounds like it could be misfiring or floating a valve. My power also instantly drops off. I have done a tune up, but not checked the timing. the wierd thing is that it happened at 5200rpm, then a few days later at 4100rpm. Im kinda pissed. also, i only have 116K on the engine with everything stock except for the sig.
ORIGINAL: tp65
That happened to my car, WOT or around 4krpm sounds like its misfiring or slightly "ticking"... turned out to be the module on the distributor going bad. Luckily I had an extra one laying around that I could swap in. I rem it drove me nuts trying to figure it out, I changed out all the vacuum hoses, tps, even downgraded my 88 back to SD from MAF cause I thought it could be the computer or MAF going bad.
well, im not sure when the fuel filter has been changed. i only had the car for a month. im going to change that first and see what happens thanks guys.
id say 9/10 its the pick up coil which is in the distrubutor. happend to me while racing a honda in my 93 GT and he ended up gettin me top end cause it was cuttin out. After that i completely understand what u mean by "breaking up".
