cobra r rims rub in fornt
hey i have a 1991 lx 5.0 and today i pre mounted my 17x9 cobra r rims on the front and when you turn the wheel all the way the rim rubs on tha a arm. any suggestions?
ps. there are no tires mounted yet
RE: cobra r rims rub in fornt
I know this may seem a little gheto rigged but you cangrind your a arms where the rim rubs the a arm,about a 1/4 of an inch. not my personal choice but it works. But the safe way to stop it is to change out to tubular a arms. I got my tubular a arms from All Mustang Performance in Phoenix for $200.00 and change.Also the newtubular aarms have the proper lower ball joints to allow you to correct the alignment properlyif you have camber caster plates. and one more thing if you grind your a arms make sure you rebalance your tires with tape weights. no more static balance they will find a way somehow to fu@%^ng catch the a arm and fly off.
they will do that.. its no biggie tho.. just make sure it doesnt rub the inner fenderwell plastic or it will wear through and ull have noise.. just push it back and up and put a screw in thereto hold them up. thats what i did and now i dont hear any noise
11-10-2015 11:39 AM
Dan04COBRA
09-30-2015 11:46 AM
ccdguy
09-19-2015 05:20 PM
