engine makin bad noise
when my engine is under ANY kind of load, it makes a noise, like pre detenation, but much much louder, and it does it when i rev it up a lil bit as well.... and if i put my ear on the center of the intake i can here it there the most, dont sound like its commin from under a valve cover.... could this be the end of my bottem end?[&:]
RE: engine makin bad noise
sounds like a bearing is trying to slip....???
sorry to hear that..i hate hearing that someone's steed is about to bite it.
look at this way time for bigger and better things.
Just for the hell of it what does your balancer look like.Mine spun and was acting the same way.I finally figured out that when I set the timing I was always 5-7 degrees off.The bad part was that I pulled the motor before I figured it out.But while it is out time for all new parts.
