remanufacture ecm?
RE: remanufacture ecm?
I have a 95 cobra, that runs rough when it is cold and when you floor it, the motor gets leaned out. Its at a mechanics he has checked every sensor, even changed fuel pump and filter. He said the only things left is injectors and the ecm. I'm taking my buddys 94 cobra so he cross check. Where can u get a 95 cobra ecm for a $100
ORIGINAL: AdderMk2
I'd be willing to bet that your mechanic didnt check crap.
pull your ECT plug and check the resistance on the sensor both while cold, and at operating temperature... post your results
If the injectors are firing then they're fine and my guess is the ECU has never been better...they're tough as nails.
Don't waste your dough buying an ECM that might NOT solve the problem......start with the basic self-tests, don't gue$$....... DIY KOEO/KOER/Cylinder Balance Self-Test
