5.0 specs
Old 06-15-2007, 01:26 AM
ktp1598
ktp1598's Avatar
Default 5.0 specs
I searched and didn't seem to come up with a good answer. I just bought a 302 out of a 1993 F150. The specs say it has 185 horsepower. This is not the same engine thats in the crown vic is it? I know everything is different on that engine. I also know I need to change the intake, throttlebody and exhaust mani. Are the heads, distributorand everything else the same as a H.O.? I will probably put an E303 in it so the cam doesn't matter much. I got a good deal on the engine (it's going in my 89 mustang LX 4 banger), so did I screw up? I don't want another 'vic engine!! Thanks in advance!
ktp1598 is offline
Old 06-15-2007, 01:57 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
Default RE: 5.0 specs
What kind of deal did you get? Crate motors pushing over 300HP are not too expensive these days...
CantStopTheFox... is offline
Old 06-15-2007, 02:16 AM
ktp1598
ktp1598's Avatar
I paid 200 for it with accessories and an engine stand. I never heard it run, but he said it had about 100K on it. Pretty low miles and no oil leaks. he even gave me a mustang oil pan.
ktp1598 is offline
Old 06-15-2007, 02:32 AM
94StinkinLincoln
94StinkinLincoln's Avatar
rebuild and stroke it...cam is what makes the big diff. in the non ho's i think...maby other little stuff, but that would be changed for performace stuff.
94StinkinLincoln is offline
Old 06-15-2007, 01:46 PM
ktp1598
ktp1598's Avatar
I have plans formore performance, but my budget will only allow so much right now. Is the firing order the same as the HO motors?
ktp1598 is offline
Old 06-15-2007, 02:14 PM
ktp1598
ktp1598's Avatar
After doing some more research comparing parts on car-part.com and autozone, The heads and crank are the same. The firing order is not, it uses a different distributor. Can I replace the distributor with a HO unit? I plan on using a HO harness and computer from a mustang.
ktp1598 is offline
Old 06-15-2007, 02:16 PM
94StinkinLincoln
you need to change the cam also...im pretty sure of that...some1 will chime in and either confirm or deny.
Old 06-15-2007, 02:18 PM
91hatchgt
91hatchgt's Avatar
ORIGINAL: ktp1598
The camshaft is what changes the firing order, not the distributor.
91hatchgt is offline
Old 06-15-2007, 02:47 PM
ktp1598
ktp1598's Avatar
The distributor is different from a HO dizzy, but can I use it in a HO application?
ktp1598 is offline
Old 06-15-2007, 03:01 PM
91hatchgt
91hatchgt's Avatar
I am not sure on the dizzy. I would guess you might have to change that as well because of where the TFI plugs into the wiring harness.
baddog671
07-26-2016 01:20 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 5.0 specs
