whats the difference
When they gave the mustang mass air in 89 what did it have before that SD? does it really make that big of a difference when looking for a five 0. because im looking at a 87 and ive been told to go 89 +
RE: whats the difference
I was thinking the same thing... but I guess swapping over to Mass air is pretty easy... I was flipping through a Jegs the other day and found that the kit to do it from Ford racing is only $600 bux.
ORIGINAL: ryanb311
does it really matter? power wise is it more restricting or anythign. what is speed density
if you want to put heads or do head work, and change the cam. then yes SD will not be the choice for this car... mass air can handle a good amount of mod's with minimal tuning
you'll want mass air for its adaptive capabilties. any upgrades you will do will be adapted to. witht the sd you will have to have a chip burned everytime you do anything that will change the performance of your car or it will run really bad, and yes they do have a conversion kit so if you cant find a good deal on an 89 or later model than get the conversion kit. my 88 has been converted so its pretty common practice.
breaking
10-02-2015 01:27 PM
mrappe
09-26-2015 10:16 AM
mungodrums
Suspension
09-24-2015 10:12 PM
