1984 Mustang Gt...
1984 Mustang Gt...
Alright i have a 1984 Mustang Gt 5.0 stock car... It is having some over heating problems after driving it for about 40 minutes... When i stop its bubbling out of the overflow bottle... If anyone has any suggestions please let me know... Thanks guys.
RE: 1984 Mustang Gt...
Also just want to let you know that i replaced the Thermostat to a 180... I replaced the gooseneck which is leaking a bit now but not a whole lot... And it is still overheating... Could the heatercore be doing that because it leaks as well... Thanks...
Well the car sat about 6 years before i just recently got it... I have not replaced neither the clutch fan or the radiator... Yet... It has a 16 radiator cap... I have a 15 if that would help ... It will overheat anywhere... Whether im in town or highway... But its fine short 30 minute drives... And if i dont drive like a jackass i guess ...
Is it overheating on the temp gauge, or just comming out the overflow? An try turning the fan by hand. If it's real easy, or you cant turn it at all, the clutch is shot. My 2 guesses would be that the radiator needs a flush from sitting, and that the cap isnt holding pressure like it should.
Overheating but the gauges is at the L? Apparently the gauge is shot. Did you put the thermo in the right way? Is there a small hole on one side of it? it should be at the top of the thermo, it lets air bubbles out. Is the water pump leaking? Check the weep hole under it. Should be dry if good. Flush the system and see if it helps. Also look into the rad, if its caked up with white stuff its junk.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
