Bump Steer??
Bump Steer??
I have Eibach Pro-kits, Tokico HP Shocks/Struts, Maximum Motorsport C/C Plates....and an Alignment.
Every once and a while, when I turn the car I get a small knock, or bump...that comes from under my feet. It almost feels like a bushing is loose, and when I turn the car it bumps.......
Then I thought it may be bump steer since the car is lowered.....What do you think??
Better yet, explain bump steer to me
RE: Bump Steer??
Off the Maximum Motorsports website:
Bumpsteer is a term for the situation where the front toe changes as the suspension moves up and down. If the toe changes more than a very small amount it will cause the car to change direction, making the car unstable and unpredictable.
RE: Bump Steer??
ORIGINAL: OnyxCobra
Maybe a motor mount is loose??
RE: Bump Steer??
ORIGINAL: blwn93gt
i would just go under the car and make sure everything is tight.
I tell you, it was easy to get those on when I could actually stand inside the engine-bay during my H/C/I....now it is going to be a lot of fun from underneath
RE: Bump Steer??
Bumpsteer is basically when you are driving a lowered car over bumpy pavement the wheel/car unexpectedly lurch to one side or another. MM bumpsteer kit is one of the best investements I have made suspension wise.
Matt's 95 Stang
10-05-2015 07:16 AM
