Ground Problem
Ground Problem
I got the motor swapped in and ready to go.............just one problem. The negitive cable on the battary, the cable that runs from it grounds somewheres????? Not sure where, the cable is a little over a foot long and I believe its somewheres on the block???
RE: Ground Problem
Usually the negative cable will ground in one or two places. Look on the fenderwell for where to ground it to. You're probably missing the bolt that connects the cable lead to the fenderwell.
RE: Ground Problem
that wire is too long from the factory, best to cut it and ground it to the ac bracket bolt, the car will like that alot better.
Always remember to keep your grounds as short as possible
RE: Ground Problem
it doesnt really m atter where your grounds go, anywhere on the block would work really. the shorter the better, just make sure you have a ground goin to everything that was origianlly there. i.e. fender, block
musnicki
09-23-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
