Do I use stock length pushrods for 351 heads with roller rockers and x cam?
Ihave finallygathered up all the parts I need before I tear apart my engine. I have a set of ported '70 DO0E 351w heads that have 7/16 studs put into them with guideplates and I have the arp spacers to bolt them on a 302.I also have a x cam with 1.6 roller rockers. I bought a set of hardened holley systemax 2 stock length pushrods for a rollercambut have heard different opinions about what length of pushrods to use. Has anyone done this swap or could help? Thanks
RE: Do I use stock length pushrods for 351 heads with roller rockers and x cam?
You need to measure what length is required for your setup....the only "opinion" that counts is the engine's......as Adder already mentioned.
ORIGINAL: 89GTdude
Unless they are too long and u start breaking pushrods like pencils. If they area little off and adjustable rocker should be able to adjust them out
Luke9222
10-22-2015 11:55 PM
