fuel pressure dropping... need your help
#31
RE: fuel pressure dropping... need your help
ORIGINAL: grabbem88
i did what you said....i'm confused i turn the key on and my gauge goes to 42psi fo a split second then
falls back to 25psi is that right????
#32
so what should the max be for a 190lph pump?
it's a summit that is installed on my car,but the ford shop had the same reading.
i guess it wouldn't hurt to get a second opinion.before i start dropping the tank.
#33
best thing I can say is contact the tech guys at Summit and ask them what the max pressure rating on that pump is, I'm sure they could tell you. and a second opinion is a good idea before messing with dropping the tank and all that's involved with doing that for sure! did you check the entire length of all your fuel lines to make sure none of them is kinked or partially mashed flat which would reduce the effective pressure reaching the injectors?? just another thing you might want to take a good look at too.
#34
i will once,i have some time...it has been sitting for months now so i'm not hurting anything.
one more question does it make more since,now that when they are plugged in it acts
than when they are unhooked (safe mode) it runs ok????
this all happened when my starter went ape ****.....kept cranking till the battery went dead
i wonder if that caused my pump to short out or something?
#38
ok it's dropped........line looked good no cracks or kinks.
the pump is a walbro so did i get a bad one or what?
one more question i put it to my battery,and it ran,but i was expecting it to take off like an rc motor.
is there anything else to look for?
mrappe
09-26-2015 10:16 AM
