Question about transmission / shifting
#21
RE: Question about transmission / shifting
Actually, give me a few min. I have some datalogs saved on my laptop. I'll see exactly what happens when it shifts (to see how many degrees I lose)
#22
I just quickly checked out a datalog from a short 2 gear run from a dig. My timing advance went from 25* to 10* when it shifted from first to second. Unfortunately I don't remember what I was doing that run (did I let it shift itself or did I manually shift it with my ratchet shifter.) Knowing how I run, it was probably a manual shift, but either wat that's a 15 degree drop. I'll have to keep track of it more during future runs.
#24
heres what I would do, convert to to a stick, tko 600, might be $2500 but well worth it and more fun to drive. Not as consistent at the track but still way more fun to drive
#25
ORIGINAL: stang8689
#26
ORIGINAL: samseed101
You're kind of on the right track. But that number doesn't mean that the timing is bumped back 5*... it means that the timing can be bumped back to 5*. Also, keep in mind that this is total timing, not base timing. Looking at the charts Adder posted... That means that you could lose 20* or more of timing depending on your situation.
Using my car for example, my total timing at WOT could go from about 25* to 5*, which would be quite a dramatic change. If I raise the min tip-in retard to match the number on the table at WOT, then that essentially eliminates any spark retard.
