5.0 H.O in Cougar?
5.0 H.O in Cougar?
There is a guy near me parting out a 1993 Cougar. The intake plate has 5.0 H.O on it. Can I use the cam and other parts to convert my 1995 truck 5.0 EFI to and H.O. motor? I was going to use the cam, wiring harness and ECU and the accessory brackets. An auto ecu will work won't it? Same power as a 5 speed? I can wait to get a 5 speed ecu, but I can get a better deal on this one. Thanks,
Bobby
Bobby
RE: 5.0 H.O in Cougar?
I was always under the impression that a 5 speed ecu had to be used with a 5 speed and an auto ecu for an auto? The 93 GT 5.0 was engine code E, so was the 93 cougar. The 95 truck was E also i think. So using the 93 cougar to upgrade the truck is a waste of money already being an HO. If im right.
just go with the cougar 5.0 there is a better chance of it being less abused than a truck. as for the computers, I dont know... not a good wiring/ECU guy. but if the cougar 5.0 is in good shape, just buy the whole motor. its the same as a mustang 5.0, you may just need a fox pan (if going into a fox...)
