mystery engine miss!!
Old 06-20-2007, 11:24 PM
corie5.02007
corie5.02007's Avatar
Default mystery engine miss!!
ok i got a 91 5.0 sd. the car started missing and running rough a few day ago. i thought it could be the engine so i hooked up a vac gauge, and the engine seems to be fine mechanically, but i cant fig. if its spark or fuel, ive had problems with the injectors in the past. but ive got spark, ohmed the coil, its fine. checked cap and rotor, its seems to be fine too. its confusing me, plz help
corie5.02007 is offline
Old 06-20-2007, 11:30 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: mystery engine miss!!
Does it miss at idle, running down the road, both/ Need a lil more info.
PRO50SC is offline
Old 06-20-2007, 11:50 PM
94StinkinLincoln
94StinkinLincoln's Avatar
fuel problem maby? pump, filter, regulator?
94StinkinLincoln is offline
Old 06-21-2007, 03:30 PM
corie5.02007
alittle at idle , more when accelerating
Old 06-21-2007, 03:53 PM
dimebag
dimebag's Avatar
does it sound like a miss? or detonation?
and sd.... meaning speed density? why is a 91 a speed density car?
dimebag is offline
Old 06-21-2007, 04:35 PM
Blckstng93
Blckstng93's Avatar
MAF replaced SD in 88-89. If you got SD it was converted from MAF. Could be a problem if it wasnt done right.
You sure its SD?
Blckstng93 is offline
Old 06-21-2007, 04:48 PM
corie5.02007
yes it does mean speed density, and no its not that. i did the conversion myself cuz my maf ecu fried. but i just found a new clue, excessive oil in the intake manifold, could that be something?andim pretty sure its amiss, the engine shakes alot when accelerating.
Old 06-21-2007, 04:49 PM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: corie5.02007
Pull your spark plugs, you may have cracked the porcelain or nose cone on one.
Derf00 is offline
Old 06-22-2007, 01:06 AM
corie5.02007
i put all new spark plugs in it, does anyone think the oil has somthing to do with it? i dont think so, cuz it feels like a ignition miss. but it could be.
Old 06-22-2007, 01:32 AM
samseed101
samseed101's Avatar
You most likely have oil in the intake because it's getting sucked up by the PCV valve and spit back into the upper. I guess ht could foul your plugs, but you said you changed them. wouldn't hurt to install an oil / air seperator anyway.
samseed101 is offline
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
vintageaion
09-08-2015 10:45 AM
09-01-2015 08:16 PM
Quick Reply: mystery engine miss!!
