Stock MAF & 24lb injectors
RE: Stock MAF & 24lb injectors
ORIGINAL: dimebag
you sir are correct..... o btw samseed... remember i was asking how to hook my -4 line to the fuel rail... the adapter from my fuel press. guage did the trick, i just took the pin out of it. so it goes... schrader valve, that adapter, then the -4 line.... its gonna work just fine
The Ford MAFs have decent accuracy and they're usually cheaper. I just sold my stock 70mm SN95 MAF for $35 shipped. And since the MAF itse'f isn't calibrated to injector size, they can use it on their applications.
Look at it this way... The Mustang GT and the Mustang Cobra use the same MAF. One car uses 19# injectors, the other uses 24# injectors, but the MAF itself is completely interchangable.
He's running 24lb's on his stang cuz a couple of his stock injectors were bad & he planned on doing a H/C/I swap but never got to it. I'm going to sell him my MAF when I install the S-Trim that I'm getting from you.
09-16-2015 07:53 PM
