another timing question
i want to bumb my engine timing to about 14 degrees but im not 100% sure that i know how to do this and yes i have read the main tread on this. the part i dont get is where to make the lines with the white out. do you just but any old line here or there or what. second does the timing light tell you how much degrees you have it set at? thanks
RE: another timing question
Most timing lights dont they are called inductive, but you can by a digital thatwill. There like one hundred dollars. Although im not sure if you just plug and play or if you have to calibrate them.
When the timing light flashes, it will always be when the balancer is at the same position. So as you advance it, you will see the line that you highlighted actually move until you stop it right where you want to stop it.
This video is a great example of how a timing light would work. (BTW, even if you already know, check out the video.. It's pretty cool) It's not quite the same, but you get the idea. In this example, the shutter speed of the camera happens to nearly exactly match the rotation. When the rotation speeds up or slows down for a split second, you can see the change as the blades appear to sloowly move forward or backwards instead of standing still. The same thing would happen when looking at teh balancer with teh timing light flashing.
Calizic
08-28-2015 01:46 PM
