Fuel Filter
Old 06-23-2007, 02:30 PM
chosen1_50
chosen1_50's Avatar
Default Fuel Filter
Where is the fuel fiter located in the 87 model V-8 5.0 Mustang?
chosen1_50 is offline
Old 06-23-2007, 02:34 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Fuel Filter
It's located between the tank and the body above the rearend. It's the one in the background of the pic
PRO50SC is offline
Old 06-23-2007, 02:37 PM
chosen1_50
chosen1_50's Avatar
......so I must drop the gas tank to get to it correct.
Old 06-23-2007, 02:39 PM
86 5.0L
86 5.0L's Avatar
nope, just raise the rear and lay on your back and you can see it clearly
86 5.0L is offline
Old 06-23-2007, 02:41 PM
chosen1_50
chosen1_50's Avatar
is it on the driver side or passenger, I'm trying to make it ez on myself.
Old 06-23-2007, 02:43 PM
5.0stanger
5.0stanger's Avatar
passenger....you don't have to lift you car, just look under it.
5.0stanger is offline
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Also you'll need to relieve the f/p before disconnecting the lines. Youcan do that by unplugging the f/p relay or unplugging the intertia switch.
PRO50SC is offline
Old 06-23-2007, 02:46 PM
chosen1_50
chosen1_50's Avatar
what is a f/p relay?
Old 06-23-2007, 02:47 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
f/p = fuel pump
PRO50SC is offline
Old 06-23-2007, 02:51 PM
chosen1_50
chosen1_50's Avatar
Thanks, after I fix that I'll be back.
Quick Reply: Fuel Filter
