clutch quad HELP
Old 06-24-2007, 03:53 PM
dimebag
dimebag's Avatar
Default clutch quad HELP
ok so this morning on the way to work the clutch quad broke. i have an extra stocker sittin around that ima use for now. i have the quad off but cannot get the other small "paw" off. the cotter pin is out, i just dont have the space to get it off. so how the **** do i go about this? and its all up in the car still, i didnt remove it.. and dont see how to...
dimebag is offline
Old 06-24-2007, 04:30 PM
945LSTANG
945LSTANG's Avatar
Default RE: clutch quad HELP
i couldnt get mine off without ripping it to shreds because of the spring. just upgrade your clutch linkage....its the perfect time since your old one broke.
945LSTANG is offline
Old 06-24-2007, 04:32 PM
Old_Smokey
Old_Smokey's Avatar
when i put my steed quad in, i ended up prying the old one off with a bar, f*cker wouldnt come out any other way.
Old_Smokey is offline
Old 06-24-2007, 04:35 PM
dimebag
dimebag's Avatar
yea i would be and will be doing an upgrade, but i dont have the money right now, just spend 250 thru summit, im tight till next check now... i happen to have another stock one laying around that im going to use. the problem im running into is that there is nowhere for the clutchpedal to go to have room for that piece to slide off of its pin... wtf guys.... and idc if it comes off all ****ed up, i have another im putting on, lol. and i can see tha the teeth on it are striped so just leaving it and swaping the quadrant would be pointless
dimebag is offline
Old 06-24-2007, 04:38 PM
Old_Smokey
Old_Smokey's Avatar
well i removed my drivers seat so I cna lay on my back and see everything. Idk if you have done that already , but when your down there looking up at the quadrant, try hitting the clutch pedal up and down with your hand and watch where it is pivoting. you should be able to see where its exactly hooked, and go from there.
FivePointToTheOh
03-09-2020 10:26 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
Quick Reply: clutch quad HELP
