Just bought afr 165
RE: Just bought afr 165
I'd just buy some springs that are recommended for your cam. Thta's what I did with my 185's not only since the cam way exceeded the AFR springs but also because it's what Comp recommends and you should follow your cam companies suggestions.
I should not have a problem with them at all. I mean they are an upgrade from stock and thats what i was using. stock heads. the seat pressure on the springs is 120 thats what lunati recomends. I need to call them about open pressure. the springs they say to use are 340 open pressure.
BeatnikFink
10-01-2015 08:00 PM
