battery relocation
battery relocation
when relocating the battery on a 95 mustang, are you supposed to run your ground cable back to the motor on the side of the timing cover where the factory one goes or is it ok to bolt it to the trunk floor?
RE: battery relocation
don't ground it to any part of your body!..the resistance will be weak and the charging system will be weak...get 00 gage cable and run it to your block..it's your best ground period.yeah you can get by with a ground strap to the trunk,but i would do it right the first time..
i'm using 0 positive cable 00 ground
ok well im just trying to figure out a buddys problem. i think its groud issues. he has the battery relocated and its grounded to the trunk floor. first he had no fuel pump so he put it on a switch instead of finding the problem and now he says hes got no spark and he started checking voltage with a dummy light and says that its good in some places but real weak in others so think its a battery ground issue?
ORIGINAL: grabbem88
well when i added my second electric fan and stereo system i did..
i also have a kill switch and relay with a 4gage cable from my alternator..also our cars for some reason display weak wiring..
did he have this problem before/after the battery relocation?
