8.8 rearend help
Old 01-10-2005, 06:28 PM
619socalstang
619socalstang's Avatar
Default 8.8 rearend help
i plan to do a complete rebuild and gaer change can anybody give me some pointers, THANKS
619socalstang is offline
Old 01-10-2005, 06:47 PM
C/Note
I ♥ Acer
C/Note's Avatar
Default RE: 8.8 rearend help
just buy a new traction lock posi with 31 splines and moser axles,,and your choice of gears...3.73 or 4.10s im going mid 10s on them
C/Note is offline
Old 01-10-2005, 06:56 PM
5.0mustang5speed
I ♥ Acer
5.0mustang5speed's Avatar
hey hotrodmanII ..wtf...is up with the picture of 2 men kissing...are you a ***? or what
5.0mustang5speed is offline
Old 01-10-2005, 07:21 PM
619socalstang
ORIGINAL: 5.0mustang5speed
you have not been here long enough to gety it.
hotrod i was talking about install tips. i have 410s and an auburn 31 spline locker.
Old 01-10-2005, 07:38 PM
vfast
I ♥ Acer
vfast's Avatar
well if your not rich like me try this
buy a clutch kit and install them..add 1 or 2 of the best of the old ones as this will tighten it up and will make a hugh difference.....do not put the 2 old ones side by side.....buy the FMS gear set as it comes with the shims,crush sleeve and gears....also replace the axle seal while you have them out as well as look at the axles and bearing for wear....I would install at least a new pinion bearing...
vfast is offline
Old 01-10-2005, 08:22 PM
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
If your new at setting gears and pinion depth I'd reccomend getting a extra crush sleeve or two. If you tighten the pinion too far you can't just back it off, it's reccomended to install a new crush sleeve and redo the pinion depth.
Grimace5.0 is offline
Old 01-10-2005, 08:28 PM
C/Note
I ♥ Acer
C/Note's Avatar
thats not me thats the gm killer..has many names and been banned many times,,,thats him and his brother he pm it to me ,,,how gay,,,
C/Note is offline
Old 01-10-2005, 08:31 PM
vfast
I ♥ Acer
vfast's Avatar
you like blacks guys
vfast is offline
Old 01-10-2005, 09:39 PM
bobby
bobby's Avatar
ORIGINAL: vfast
bobby is offline
Matt's 95 Stang
10-05-2015 07:16 AM
67LimeCoupe
09-30-2015 04:46 PM
67LimeCoupe
09-21-2015 06:34 PM
DCole24
09-11-2015 10:50 AM
67LimeCoupe
09-02-2015 08:02 AM
Quick Reply: 8.8 rearend help
