Heads and block match up?
I dont get it, both heads are off mustangs, i have a both pairs, which should be better, and why dont the coolant passages line up to be the same and why isnt the black head have the same passages as the block?
RE: Heads and block match up?
well thers only one way to find out......put em on
well since im the jurry riger here i would.......use a dremel or air tool and put the gasket on the head mark were the water passage is and grind over to it.......should work your just making the passage alil bigger?on second thought scratch that just open the wallet and get another set of heads
