Suggestions for intake swap?
Hey everyone was wondering what are some suggestions for an intake and throttle body swap? Right now i have a 1991 mustang 5.0 with ram air hood with cold air induction kit, underdrive pullies, shorty headers, aftermarket h pipe with flowmaster exhaust. the tranny is an aod with shift kit. running 3.55 gears in the rear end. got quad shock set up on rear and subframe connectors on the car also. i know i will have to go with a bigger maf sensor when i swap out the tb. any suggestions on an intake and throttle body combo and what size maf to go with also? the motor is all stockinternally nothinghas been modified. would it be ideal to swap out and put bigger fuel injectors in also while im doing the swap? any help would be appreciated. i am new to this site and think the knowledge base here is awesome. so many people with alot of good ideas. thanks
RE: Suggestions for intake swap?
If money is no issue... go for the GT-40 Intake Manifold by Ford Motorsport. Its expensive but really nice. The Trick Flow stuff is really nice to and they offer some sick packages. As for injectors that'd be a good idea but i do believe you'd have to change over your fuel pump to. BBK also makes some really nice throttle bodies as well. I'll give you some links to these parts. Hope this helps you out.
http://www.themustangshop.ca/site/ca...er=TTYwMDFBNTA=
http://www.themustangshop.ca/site/ca...er=NTE1MTEwMDE=
i rather buy that trick flow then that gt-40 that gt-40 is a real nice piece but for half the price you get an intake that flows about the same if not better then a gt-40 it all depends in your future plans if u plan on running a turbo or supper charger i would go with an eldelbrock rpm II just my 2 cents
panic
09-10-2015 05:56 PM
