is it really worth it?
Old 01-11-2005, 05:34 PM
4fit?
4fit?'s Avatar
Default RE: is it really worth it?
ORIGINAL: Aliate X
How hard is the install?
Should take you -30 minutes. Now, adjusting the stops to the way you want it could take a little longer.
4fit? is offline
Old 01-11-2005, 06:55 PM
vfast
I ♥ Acer
vfast's Avatar
pro 5.0 is a nice piece as is the UPR TRIAXLE just like steeda but about 40-50 less
vfast is offline
Old 01-11-2005, 09:24 PM
sc94gt
sc94gt's Avatar
I installed my Pro-5.0 last summer. It took about 30 minutes and was so easy I should have done it long ago.
Make sure you scrape off all of the old gasket material and install a good bead of High Temp silicon. Give it 24 hours to dry also.
The shifts are so quick now, and 5th to 3rd is way faster and no fear of missing and grinding... like one smoothe motion! Its because the shifter springs to the middle.
They don't recommend "slamming" the gears, but the stop bolts let you do it.
Get one!
sc94gt is offline
Old 01-11-2005, 09:54 PM
1994gtchris
1994gtchris's Avatar
sc94gt how does your car run with that blower i was thinkin about gettin one,was it a huge defference?one other thing what do you guys think about the hurst short throw? -chris-
1994gtchris is offline
Old 01-12-2005, 01:25 AM
sc94gt
sc94gt's Avatar
The blower made a big difference... but then I did the exhaust a couple months later and it really opened it up.
Installing it took a couple days, mostly due to the poor installation manual provided with the kit (horrible photocopy pictures in it).
Once installed, it's was a matter of fixing the idle and trying to get more serpentine belt to loop around the alt.
Upon startup, since you lose the idle tensioner pulley (no space for it anymore) you get a little belt squeal.
Solution... I took the pulley off the discarded tensioner and rerouted it to get more belt around the alt. so no more slippage of that tiny pulley.
Gas mileage didn't change much, except now I must use high test fuel.
One of the cool features is that it is a quiet blower. Also, if something happens to the blower you can just take the belt off and run the car stock.
There is no plumbing for oil and stock 19# injectors work just fine since the FMU is keeping the enigne really rich.
Whichever blower you get, bigger headers really work nice in combination with it.
I have no problem running with the 2005 Mustangs now.
sc94gt is offline
Old 01-12-2005, 02:03 AM
Dan89lx
Dan89lx's Avatar
i didnt realize the Ripper shifter was so popular
Dan89lx is offline
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
2015Ecoboost
09-17-2015 01:48 PM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
Quick Reply: is it really worth it?
