PTV CLEARANCE AND SPRING CAPACITY
RE: PTV CLEARANCE AND SPRING CAPACITY
PR length needs to be set by checking for the correct geometry, it should be the last valvetrain component you should buy after doing the measurements.
I used a set on a friends car the scorpion roller rocker that is...and they run the car weekly at the track and to my amazement those darn things were quieter then any roller rocker I've put on any of my cars and I usually buy the expensive ones[:'(]oh well ,,,,,, anyway from what I've seen they work okay.. alittle on the bulky side though..so make sure you have valve cover clearence
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
