PTV CLEARANCE AND SPRING CAPACITY
Well as most of you know im planning an exploder engine swap
with a steeda #19 cam and bbk unequal lenghth headers wich i have already ordered. Now im debating on the roller rockers i want to put 1.7 but im wondering will the piston to valve clearance be ok
i dont have the specs for lift and duration on this cam and also with 1.7 rollers will the stock springs handle it. The motor has 68k on it and its a 00 exploder i dont want totake the heads off.
RE: PTV CLEARANCE AND SPRING CAPACITY
i found out that the cobras also cam with 1.7's so i guess it should be ok, im just nervous and i want everything to go smooth the first time.
What do you guys think about scorpion brand roller rockers?
what kind of springs do you guys recommend.
are these good for my application?http://store.summitracing.com/partde...p;autoview=sku
You need a kit with valve retainers (exhaust springs seat lower than the intake).....+ you would need to fit the heads with nylon valve seals (inner spring ID) with those springs......here are some options you could check....
1. TFS upgrade kit
2. FMS-M-6514-B50 retainers + FMS-M-6513-A50 valve springs
1. TFS upgrade kit
