throwout bearing or everything? - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang
Reload this Page >
Old 06-29-2007, 01:58 AM
91bigredgt
Default throwout bearing or everything?
ok a few weeks ago i started hearing a squeeling noise coming from the front of the car, not brake squeeling but when i let off the clutch all the way it will make the noise and if i give it the slightest bit of pressure it will stop. now ive read that this is the throwout bearing, but now it seems like ive got a bigger problem. i just bought the car in april and learned to drive it as well with no slip ups (as far as gears and the clutch) the previous owner told me that he just had a new clutch put in and he wasnt lyin but i think they didnt replace the throwout bearing cause it doesnt seem likely that the clutch would be that strong and yet the supposive new bearing is already going. recently my clutch became alittle softer and the pedal is going all the way down and clicking and there is the clutch smell every now and then. im not sure what to replace the bearing or just get the whole clutch setup
91bigredgt is offline
Old 06-29-2007, 02:00 AM
91bigredgt
Default RE: throwout bearing or everything?
sorry in advance on puncuation and stuff kinda in a rush
Old 06-29-2007, 02:04 AM
onetrickpony
When I first put my new clutch and throw out bearing in it started to make a little squeal and I was told that they will do that sometimes and that it goes away, and it did. The clutch cable might need adjusted. You have to go through alot just to replace the throw out bearing. If it were me since the tranny will be out I would just go ahead and just replace the fly wheel, clutch and throw out bearing. This way you know for sure that it is all new.
onetrickpony is offline
Old 06-29-2007, 02:09 AM
91bigredgt
well up until a few weeks ago that clutch was very new feeling and i hear if the bearing is going i will have major problems if it breaks. just kinda being cautious cause this is my dd and only car
Old 06-29-2007, 02:10 AM
keller5.0
Same thing happened to me when I bought my mustang. There was a new clutch in it, but the cheap assdidnt replace the throwout bearing. It sounds like you have a throwout bearing problem. If youre going to tear the car down to replace a throwout bearing, you might as well get the flywheel re-surfaced and replace the clutch. You would hate to not replace the clutch,just tofind out things still arent right after you get it all put back together.
keller5.0 is offline
Old 06-29-2007, 02:35 AM
HACKGT350
HACKGT350's Avatar
they are right about that if you are gunna take it out to replace the bearing. as for the pedal feel it could be that your clutch quadrant is on its way out and needs to be replaced. thats very common the stock plasic one is junk and breaks.
HACKGT350 is offline
Old 06-29-2007, 02:47 AM
91bigredgt
i just wish there was a way to find out if the bearing is really going or if this is just the new clutch squeel that some people were saying. if it helps any the squeel isnt constant it will do it for awhile usually in 2nd or 3rd and stop for awhile and come back
Old 06-29-2007, 02:50 AM
HACKGT350
HACKGT350's Avatar
how long has it been doing this for?
Old 06-29-2007, 03:18 AM
iceman89gt
if you have to go all the way to the flywheel be sure and get a new one piece rear main gasket also.
iceman89gt is offline
Old 06-29-2007, 03:45 AM
91bigredgt
a few weeks as of now
Quick Reply: throwout bearing or everything?
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
