supercharger
supercharger
hey guys. i just got my 3rd mustang and im gonna sell the other 2 and supercharge the 1st one i got how much do they cost and my whole motor is stock what do i need to alllow a superchager and how musch do they run for? how much psi should i be running ill have about 3k to add to a superchager and motor mods the car i have has 45000 original miles
RE: supercharger
sc will run you 2200-4000 depending on the make/moddle and extras you buy. youll need a bigger fuel pump and bigger injectors. a maf calibrated for those bigger injectors too. youll need a dyno tune and custom chip which will run you $500+ plan on more then $3k for a good set up.
id start at 8psi of boost and work my way up
RE: supercharger
yea i just want to buy the supercharger im not looking for anyhting special i just got 3k at leat to waist on my mustang, im just wondering what i will need to assist the superhcarer in orsder to not hurt my motor
RE: supercharger
everything i mentioned is needed. you need:
the sc
bigger fuel injectors
a maf sensor calibrated to those injectors
bigger fuel pump
custom tune/chip so that the motor doent blow up under boost
things that you should have but arent 100% needed:
msd box
better exhaust
larger tb
better intake
better heads
msd coil
the sc
bigger fuel pump
msd box
better exhaust
larger tb
better intake
better heads
msd coil
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
